denon avr 3600 help
hzoskiers2001
a friend moved house lost manual for avr 3600 managed to get all the sound going eg dvd paytv video setop box
what is the best way to setup the video output so that when you press dvd the video switches as well as audio
when you press paytv the video output changes as well as the audio
when you press video the video changes as well as audio
if you just av cable from monitor output on amp will this switch outputs of difffent componets eg dvd video
any help would be appreciated
MDS
All receivers use the audio follows video paradigm. If you use analog audio connections and they are connected to the same input as the video connection or you use digital audio connections and assign the audio to the same input that receives the video, the switching happens automatically and there is nothing extra that need be done.
