denon AVR 3310CI net/usb
  • Thread starter Thread starter MGOETZ
MGOETZ
4
0
0
My denon AVR 3310 Ci keeps trying to connect to my home network. It has never been connected, nor have I ever attempted to coonect it. It simply started to try to connect today. No ethernet cable connected to it. when I switch it to any output function it switches itself to NET/USB and then trys to connect. I have been through the menus and attempted to disable the network. No help.
Is there a battery somewhere that should be replaced? There is a PS3, Cable, and epson projector wired through the denon.
Does any one have any Ideas.
Did not work. Thinking about doing a system restore on it.
That would be a last resort though.
Denon got back to me on this. Open the front panel a simultaneously hold the UP and DOWN arrows while pressing the on/off switch.
Is that a hard reset (what you refer to as, system restore) for Denon receivers?
It is on my Denon X4000. Resets all values to factory settings... but also cleared a problem I was having w/ Zone 2.
  • Like
Reactions: ReUpRo
There is a different button combination for factory reset. This was to reset the net/us card. After a few blinks on the front face though everything was back to normal.
  • Like
Reactions: ReUpRo
