Denon AVR-3300 set up help.
sdstarnes
I have a Denon AVR-3300 receiver and are using the 5.1 plus a subwoofer setup. I have an HD cable box and a Blue Ray DVD player and these are connected to the digital in jacks on the receiver. My problem is that I am not able to get the 5.1 sound comming off of the cable box, but can with the DVD. Is this a setup issue? Any AVR-3300 experts out there? Any help would be greatly appreciated. :confused:
***sdstarnes@earthlink.net***
adk highlander
adk highlander
Sith Lord
Hello sdstarnes welcome to the forum.
Are you getting any sound from the cable box or just no 5.1? Many broadcasts are only in stereo so you must use Dolby PLx to create a surround effect from the stereo source. If the programing is coming in Dolby Digital then your receiver should decode it and give descrete 5.1 surround sound.
Does this model decode Dolby Digital? You said your DVD player is giving you 5.1. Is it decoding the format or are you havin the receiver decoding? I'll look for a manual shortly to see what your receiver will do.
