kenhoeve said:
You gotta get the OSD working, don't know how you would do anything without it(especially assigning audio/video combinations). I'm confused about your video connections to the TV from the receiver. Keep in mind that the 480i signal from the receiver will not overlay a 720 or 1080 signal from the receiver.
You are correct, sir. I kinda just figured out the 480i thing when I slowed down to try and decode some of the gibberish in the owners manual. It's late and I'm tired and frustrated, but I'm getting there.
As for the MIA OSD, the front panel seems to have a pretty good message system that lets you know where you are, so I was able to assign everything through the front panel messages. Although, there was a time when the front panel would blank out and I couldn't get it to come back up no-how.
Anyway, am I supposed to run a composite or S-video line to the TV to see the OSD and change the TV input just to use the menu?
Oh, and I solved numbers B and C in the meanwhile. It turns out there is an input button on the remote that changes the audio input source of whatever you're watching, over-riding the settings in the set-up menu. Also, I'm running my 3.1 in 5 channel stereo and it seems to work OK. I'm open to better suggestions here, too.
