CPA
Hello all,
I just upgraded my home theater system to include a Denon AVR 2105 and a Sony DVD/CD changer - DVp-NC875V. I have 5 channel surround with Paradigm speakers.
I believe I properly followed all the directions - I used a digital coax to go from the DVD player to the receiver, a component cable for video, and then I also used a 6 channel audio cable for the SACD. I have a BIG problem though. I get audio when playing either a CD or a DVD, but the CD's play at an ear splitting volume, the DVD plays loud as well, and the master volume on the receiver does not seem to be able to change the volume at all. Meanwhile, I ran my TV sound through the receiver but that seems to work fine. What the heck did I do wrong? I am worried there may be some incompatibility or other issue and would like to make sure everything gets under control while I'm under my 30 day return period.
Thanks.
Thanks.
