I am having difficulty with the sound on my Dennon receiver. The model number is AVR-1910. * The problem seems to be with the HDMI connection. The connection carries the video signal fine but will not carry the audio signal. * I have run a couple of tests to isolate the problem. Firstly I have changed the HDMI cables several times to ensure that they were not the problem. Secondly I have put the HDMI cables into each of the four separate HDMI inputs to ensure that one of them is not the problem. Thirdly I have eliminated the HDMI output by simply using headphones while watching TV. Obviously I could see the picture but I cannot get any sound. * I can however get sound if I hook the cable box up to the simple RCA audio connections. * Consequently that shows me that the problem seems to be with the HDMI input. I wonder if there is something that needs to be reset on the system in order for that to work or if it is some kind of mechanical/electrical/circuitry problem. * The system was working fine until about 3 months ago and then stopped working. There was nothing untoward that I could see that would have caused it to stop working. * Any advice that you could give me as to how I can correct this problem would be greatly appreciated. *
