tntdio
I have a Denon avr-689 and can't get the am/fm tuner working, I have followed the few steps in the manual, what am I overlooking, didn't think it should be difficult getting this working.
What are you using to an antenna, and how far are you away from transmitters, and what is in between you and the transmitters?I have a Denon avr-689 and can't get the am/fm tuner working, I have followed the few steps in the manual, what am I overlooking, didn't think it should be difficult getting this working.
What sort of reception do you get on your car radio at that location?I am only using the FM indoor antenna that came with the unit, which is set up in the family room, heaps of windows on a busy suburban street.
Is it making any weird noises or just not tuning into the stations? If you set it for manual tuning and go to a station that you know, what happens?I have a Denon avr-689 and can't get the am/fm tuner working, I have followed the few steps in the manual, what am I overlooking, didn't think it should be difficult getting this working.
