N
n2myvideo
Anyone familiar with setting up the Denon 5803 in a manner
in which I can play CD 1 to listen to music outside on a separte
set of speakers, while everyone indoors watches TV or a DVD
on a different set of speakers indoors?
JohnA
JohnA
Here you go
There is an option for a Zone 2...it should be "speaker B" or something like that (make sure to read the manual for setting up a seperate zone) make sure that if you are using a digital audio source, that you also use the anolog, zone 2 only uses anolog inputs. There is a menu function that allows you to individualy select what input is going to both zone 1 and zone 2. Hope that helps :)
