DENON 4520 - Audyess XT32ci platinum edition.
Can anyone tell me with certainty that you can run Audessy Xt32 on a Denon 4520ci using as a pre/ pr
  • Yes it will but???
  • Yes easily done.
Results are only viewable after voting.
Audio A
I've been running my 5.2 thru an Emotiva XPA 5 Gen 2 and was running other height speaker thru assigning amps in setting I could still use Audessey, Dynamic eq... Etc. I'm about to relieve my 4520 of all amp duties and just run all channels and multi zones thru other amps. THE Question is before I dive in to breakdown and get elbow deep in wires and small places.... Can SOMEONE ANYONE TELL ME WITH CERTAINTY THAT THE AUDESSEY PLATNUM IS STILL GOINH TO CALIBRATE my Audio EVEN THOUGH IN SET UP THERE WILL BE NO CONNECTED SPEAKERS to the Denon???? It just gonna be a pre--pro. Advice would be greatly appreciated or any help to the answer pretty quickly. I'll be starting while most of you are still sleeping. Dang it. I miss sleeping. But I've got the bug!!
Thanks guys!!
KenM10759
KenM10759
The mic for the Audyssey is still going into the AVR4520, and all pre-processing and corrections are still applied there before the pre-amped signal is sent via its pre-outs to another amp.
You're good.
agarwalro
agarwalro
You'll need to rerun Audyssey so that levels get readjusted. Other than that, there should be no issue.
Audio A
Awesome! Thank you guys. When ever I start tinkering with amp setting I change an amp assignment, like say to the FH, I change to Wides. When I hear it that way and then flip back to my original Audessey eq setting they don't come back and the sound is sound turns to Graffic EQ and it sounds terrible!?? I have to rerun Aud eq all over again to get the best sound back! What's that about then?? I thought it was bc I was playing with the amp or channel settings? But not able to revert back to the last Aud Eq settings I don't understand. Well good news is it should work. So we'll see. I'll report back with mmmm, something Positive u hope. Ha!
