Denon 4308 Bi-AMP/Bi-Wire
Pell
I am new to the concept of Bi-Amp and Bi-Wire . The Denon 4308 has "both" but I am confused on which to use and I have never owned a denon so dont know if somethings wrong.
I have set it to Bi-Amp which states that if you use the AMP/2 port (there are two ports like that) it will Bi-Amp. There is also a setting that does the exact same thing with Bi-Wire.
My problem is I am unsure if this is working properly, when I do the Auto Setup you can hear the other channels have great treble but the fronts do not. THe tweeters are working (i tried unplugging and replugging from the back of the receiver to confirm) , also when u look at the graph of the speakers results it shows all results for the fronts above a certain level just flatlined as if no signal reached it at all.
So to my actual question, should i Bi-WIRE or BI-AMP on this specific receiver? I always thought Bi-Amping meant you had 2 seperate amps and bi-wire from the same amp, the thing is since this amp has a few seperate power sources i thought perhaps it could bi-amp.
I posted it in this forum because I am pretty ignorant on the matter so was hoping someone could shed some light.
THanks in advance.
Pell
update
I tried the 'bi-wiring' selection and it seems to have greatly improved treble in the front speakers (sounds identical to the center speaker) . I am guessing Bi-Amping is for a 2nd amplifier all together.
Again I am asking to understand better.
