How does the Denon 4306 distribute power? it is 130 watts times 7
how is that distributed. i.e. say if i had a behringer A500 amp lying around from my guitar and drum band set-up would it be better to bridge it on the center channel or use if for the fronts or take some of the load off of the receiver by using to just power the surrounds.
I ask this because the A500 is 160 watt i think, the denon is 130 watt but not all channels driven i believe, so quality audio wise where would i get my best bang for a buck to help the denon as a pre/pro until further monies or until my next upgrade takes place.
thanks in advance for all inputs
my setup
denon avr 4306
polk cti12-fronts
polk fxi5-surrounds
polk csi5 -center
