Denon 3805 Remote - Learning Function
avliner
avliner
Hi there,
after a while tweaking with my new baby, I finally decided to start using the learning functions, in order to avoid using 6 other remotes.
The problem I'm facing is that if I follow the manual steps, there's no way to make the other components to be operated thru the Denon remote.
As everybody knows, their manual really sucks and I believe there's gotta be some missing links in how to correctly program the remote (step by step), apart of several issues related to the remote itself.
Any inputs will be most appreciated.
Cheers / Avliner
