Denon 3805 Question
ctribble
When I hook up the calibration microphone on the Denon 3805 should I tweak the subwoofer DB level. Right now it's saying -4.5. I have JBL 250p subwoofer turned up all the way to "max" level. What should I have the actual sub turned to and what do you recommend my receiver be tweaked to?
Thanks
C.T.
shokhead
shokhead
I'd start with the sub volume on the sub at 1/2 to 3/4 and then do your auto setup. After setup,you can tweak as you like.
