Denon 3805 Pre-Out Spec
Snarl
I'm trying to figure out what the output voltage range at the Pre-Outs is on my Denon AVR-3805. I'm using an external Outlaw 755 Amplifier that indicates an input voltage of 1.43 Volts for maximum Output however I'm not sure what the Pre-Out will put out on the Denon, the spec is no doubt in the manual but I'm either not understanding it or missing it altogether. If anyone can confirm I'd appreciate it.
Thanks
Buckeyefan 1
Buckeyefan 1
Thanks
Per the manual, it appears it's 1.2 volts.
Snarl
Thanks Buckeyefan, I had noted that but still wasn't sure (some times I like things spelled out for me) and was concerned with that spec as it indicated that the Denon could never drive the Outlaw to maximum rated output. The fact that you came to the same conclusion makes me feel better knowing that I'm on the right track :) . Not that I run my system full tilt but wanted to have a reference I could trust when relating Volume Knob position to Amp output (Hey it keeps me off the streets at night :) ).
