i have a denon 2805, which has less power than the 3805. i have had multiple amplifiers hooked up this year, and they do make a difference. the amps, in order of preference: 1) cary audio cinema 5, 2)krell showcase 5, 3) B&K reference 125.2 4) nakamichi PA-5 II, 5) rotel 1080. cary audio makes a 3 channel 200 wpc amp, the cinema 3, i would guess msrp is 3000+. all of the amps, with the exception of the rotel, sounded better when hooked w/ a pre-amp as opposed to using the 2805 as a pre-pro. my fav amp using the 2805 as a pre-pro was the krell, but best sound i have found from the demos was cary audio cinema 6 pre/pro & cinema 5 amp combo. best bang for the buck was B&K, also paired well w/ 2805, but not as clean & detailed as the krell. krell was also a black hole in terms of noise, there was none. i'm still shopping, going to eventually buy a AV pre/pro from ??? and a 5 channel amp from krell, cary audio, mcintosh or ??
