mulester7 said:
.....TDeluce, I suspect there are persons at this site who would love to hear a report....one item, check your specs in the manual accompanying the amp....what is the damping factor rating?......
May not get to hooking it up tonight - might have to wait until tomorrow -
orderd some new Blue Jean cables that didn't come in today and don't
want to mess with the wiring twice...
But the only specs in the manual I have other than those below is that
the amps are hand assembled hand tested before shipping ( mine
was tested on 11-07-05 ) and found to have a THD+N of 0.005 ( yes!
three decimal places ) in each channel with a 4 ohm load and a
SNR of 117.0 ; 116.9; 117.1 in the LCR amps respectively - pretty frig'in amazing if true...
You can remove each amplifier for service by simply pulling it out and
the other two will continue to work just fine...
It has a 20 AMP circuit breaker on the back panel a 20 amp rated
cord is also supplied.
They claim to have developed a 15GHz! switcher that allowed their
engineers to use a lesser number of components in the audio path.
"Users are able to enjoy pure music, untainted by component distortion."
I have two 20 Amp isolated circuits and I am going to place this bad
boy on one of them all alone
---- specs --------------
Number of channels: Three discrete monaural blocks.
Power rating per channel:
(8-ohm load), all channels driven: 300 watts.
(4-ohm load), all channels driven: 600 watts.
(2-ohm load), all channels driven: 1000 watts.
Freq. Response (@1 W w/ ±0.1dB: 20 Hz to 20 kHz.
Channel separation: greater than 95 dB.
Max. input voltage: 1.9 volts.
Input impedance: 27,000 ohms.
Total harmonic distortion -THD:
1 kHz, 8-ohm load: 0.001%.
20 kHz, 8-ohm load: 0.003%.
1 kHz, 4-ohm load: 0.003%.
20 kHz, 4-ohm load: 0.006%.
1 kHz, 2-ohm load: 0.005%.
20 kHz, 2-ohm load: 0.006%.
Signal to noise ratio:
@ 1 kHz, 112 dB.
@ 5 kHz, 111 dB.
@ 10 kHz, 110 dB.
High-pass / low pass variable filter, range 20 Hz to 5 kHz (one/ channel).
High-pass/Full range/Low pass operation via 3-way switches (one switch per channel).
Dimensions: 9.25" x 18" x 21" (H x W x D).
Gross Weight : 119 lbs .
