denon 2910 firmware upgrade
cd992vette
Does the D21Zsaud firmware upgrade for the 2910 address what Ray Adkins is referring to in his review? The following is taken from Ray's review;I was able to obtain perfect Blacker than black and perfect whiter than white with all three of the monitors I used. However, shadow detail was not correct; I reselected 7.5 IRE and then calibrated black level using the setup menu in the display devices rather than the DVD player. I have been told that the current firmware upgrade has corrected the 7.5 IRE black level gain and is available to all current owners of the DVD-2910. Note that you can see the change made to the image because the picture setup menu is minimized when you adjust a specific item.
RLA
RLA
Hello
The installation of new firmware and making meticulous adjustments in the
"User" menu under picture controls will provide accurate black and white levels
Happy Tweaking ;)
Max997
I have the same player and I wasnt aware there was an update but after reading this I decided to check it out.
I went to the denon site and logged in with my units serial number but it tells me there are No applicable updates or upgrades are available for this model at this time
RLA
RLA
What firmware verision do you have installed on the player?
Guys, this player does require some tweaking in the user picture settings
and you must choose either 0 or 7.5 IRE in the setup menu depending on your display device for correct gray scale tracking.
