Denon 2910, DVI or HDMI?
alpharetta
Denon dvd player 2910 has both DVI and HDMI output. I wonder what port I should use to connect player to my Samsung DLP tivi just for Video signal. For audio, I will hook up the dvd player with my Yam v2500 receiver.
The component video cable comes with the Dvd player. Some people say it's good enough, don't bother to buy expensive DVI cable... I would like to get your advice. Thanks
Alpharetta
DVI is video only, so if you aren't looking for audio also, that would seem to be the best choice.
O
ozdvduser
Alpharetta
For my setup, DVI is stunning on the PJ.
jcPanny
jcPanny
On new displays and receivers, HDMI seams to be the more common digital video interface, so purchasing an HDMI cable might be a better "investment".
The video signal of an HDMI cable is identical to DVI so the video quality will be the same.
