First post here but I hope you all can help.
I decided to finally hook all my surround sound stuff back up after moving across the country in March.
I have a Denon AVR-2112CI and when i booted everything back up, the left front channel is significantly lower and distorted.
I have checked multiple speakers off this channel (the speakers work on the other channels) and using test tones, its output level is quite reduced.
I have reset the microprocessor and this still did not provide any relief.
I live in Houston, TX, but my first choice would be to avoid sending the unit back in for repair.
Are there any more troubleshooting items that i could be doing in order to fix my problem, or can anyone take a guess as to what might be happening with my receiver.
Thanks in advance for your help.
Best Regards,
Will
