denon 2105 or better
digthis
Hey,
Recently purchased denon 2105,, I have a Sanyo 32'' tv with video input,,,,I've set-up evrything like the book says but still cannot get the onscreen display on my tv,,, Denon does mention the fact that the display is made for higher definition tv's and a lower resolutions the lettering would be real small,,, but I don't even get the small lettering,,, anybody have this problem? digthis
V
VMastro
See if you can get a display using component connections. I can't on my 3802. You may have to use s video for the on screen display to work.
L
Leprkon
V is very likely right. many of today's mid and upper-mid line receivers won't send the OSD over component cables. You could have spent another $ 500 above your 2105 and still had to run a S-video or composite cable just to be able to see your menu.
digthis
Hey,
Well,,, The audio warehouse fellow said it would work so I'll put the PRESSURE on him,,,No s-video on tv! just on the dish network sat,,, The instructions are sort of vague, This was one of the main reasons that I bought reciever was
for it's on screen display! digthis
shokhead
shokhead
2805 with componenets to sony 30",osd works to set up Denon and DVD plays menu works to. Denons menu has a osd on/off and put the sony on the right video you hooked up to.
digthis
Hey,
I got it to work fine on mine, you can use component, the book says s-video is like default? there's a word I want to use but can't spit it out right now! Also it would help to put it on video 1 { DUUUHHH!} , works well and should work on all denon avr receivers. TIA digthis
