Denon 2105+DVD-2900 or 2805+DVD-2200
U
Unregistered
Guest
What's the better choice for 70% music (CD / DVD-A / SACD) 30% movies:
1 - AVR-2105 + DVD-2900
2 - AVR-2805 + DVD-2200
I'm thinking that given that DVD-A and SACD will be connected to these receivers via analog input money is better spent on the better DVD-2900 converters. Right / wrong?
What's your take on the 2105 vs 2805?
Thank you for your informed opinions.
F
Falp
Avr2105+Dv1400
Avr2805+dv2200/dv2910
Separate CD player if you think it's worth it for you
U
Unregistered
Guest
What's the difference between the 2105 and 2805 in musicality?
Both have enough power features for my needds. From the specs the main differences I could see were that _may_ affect musicality are
- 2805 has room EQ vs 2105 doesn't (however reviews of this feature are rather mixed)
- 2805 has 2 AD converters by channel vs 1 for the 2105
Doe they make a real difference?
Anything else I missed that justifies preferring?
Thanks again!
