Hello.
I have my current theater system with the Definitive Technology speakers BP700osc, CLR3000 and BPVX, Running with a Yamaha HTR 5890. (I had it from Before the speakers).
Now I been trying to find the best way to power the speakers. What will you guys recomend me to use since the 7000sc is rated at 1000 whatts and the others at 400.
I will like to keep it under $20,000.00
I don't mind using something shiper if it will be offering as good of sound quality as the expensive options.
Thanks
