What are you trying to achieve?
The center out is normally for voice conversation. Some of the centeres have a bass subwoofer ( example Def Tech CLR3000) to provide a full range of vocal sound on the center channel with sub, mid, tweeter.
If you are only going to drive a sub, it seems most of the normal voice range 4,000Hz -18,000Hz will be well above the upper limit of the sub.
