As far as the receiver goes you need to figure out what your max budget is and what feature set you will need. Most of us use the receiver for both audio/video switching. Meaning that the video and audio both pass through the receiver, the receiver is used as a switch. That way you will only have to run one set of cables to the TV and the receiver will do all of the switching for you. So this brings into question how many componets do you have? DVD, Cable/Sat Box, Game console, etc. And how many (if any) are High-Def or are you planning on going Hi-Def in the near future. This will play into how many component/HDMI inputs/outputs you will need on the receiver. Taking all of this into consideration you can then look at your options and we can chime in with our input as well. Welcome to the forums. Give us some feedback and we will try to help you out. There are a ton of great folks here!!!!!!!!!!
