Receiver connections
Ellover,
Your best is to use a digital optical or coax connection for audio from the PC to the receiver. Make sure your PC sound card has this output, if not, upgrade. There are several good options in your price range from Yamaha, Denon, Pioneer, and others. As suggested, you should select the speakers first and then pick a receiver with the power and features you need.
