Decade+ old AV Receiver upgrade
L
LALi
Hi this is my first post on this forum!
My question might sound silly but looking for pros opinion on this.
In terms of absolute sound quality only, will there be a big difference if upgrading a 12 -13 year old av receiver? Lets consider if it’s going from Yamaha Rx-v1900 to Yamaha A6A ?
Edit:
Sorry i should have posted my system details earlier here it goes:
Amp yamaha rx-v 1900 - 130w range
receiver running 7.1
Av source : Nvidia shield tv pro
Front: Paradigm monitor 11 V6
Center: Paradigm monitor cc290 v6
Surround: paradigm monitor mini v7
Front presence/height: paradigm monitor atom v7
Sub: paradigm dsp3400
Projector: Optoma UHD 38x
Denon dvd player 1930 or 2930 which now hardly used.
60% music videos 40% movies mostly on youtube and netflix
Getting that urge to upgrade my system considering av receiver for now or it should be the front speakers? Though speakers still sound great just like when bought new !
TankTop5
Are you using the older AVR internal DAC or an external DAC? Still it probably doesn’t matter much and you probably can’t hear a difference. Short answer is probably no. Long answer is it depends on your source but still probably no
everettT
everettT
Maybe listing your equipment would help?
BoredSysAdmin
BoredSysAdmin
Apples for apples - IE: In direct play mode the difference would be negligible, however, newer AVR has better room autoconfiguration, and support for 4k and 8k, including HDR10+. Many newer audio and video formats which 15yo AVR can't handle like Dolby Atmos & Vision. And many other electric features that you may or may not want. Just read the features/spec list.
L
LALi
No external dac just as it is the av receiver it self.
Here are my system details:
L
LALi
-Jim-
-Jim-
Hi @LALi welcome to the Forum.
IMHO, your sources will limit your sound quality far more than any av receiver upgrade. I know this will seem strange, but get a Blu-ray player (borrow?) and play a well recorded concert of your favorite Band at a decent volume with a lossless audio stream, from the best listening position, to see just what your system can do. Of course I'm assuming your system is setup correctly for the room to optimize the experience.
I hope this is helpful.
Eppie
Eppie
Short answer, not very likely. I try and match my AVR to the capabilities of the TV and the speaker setup. I got over 10 years out of my Denon 2310ci and Panasonic plasma but when I upgraded to a larger 4K OLED TV, I decided to upgrade to a 4k AVR and add ATMOS speakers. The Denon X4800H is more capable but the speakers do not sound any better. I just get a better image and better surround effects. The 2310 and plasma TV were moved in to the living room with a 5 channel setup and are still working great today.
If you want an improvement in audio quality, I would look at upgrading the speakers. I would consider upgrading the front 3. The Mini Monitor v7 should be ok for surround duty. I think the Premier line from Paradigm would be a step up from the Monitors but it all depends on what your budget is and where you're located. It helps greatly if there is a local dealer where you can listen first hand.
