Sorry if you missed same priced F-20, but now they gone here is another Klipsch deal:
Klipsch Synergy F-10
Specifications
FREQUENCY RESPONSE 39Hz-23KHz ± 3dB
POWER HANDLING 100W RMS / 400W Peak
SENSITIVITY 93.5dB @ 2.83V / 1m
NOMINAL IMPEDANCE 8 ohms compatible
CROSSOVER FREQUENCY 1800Hz
HIGH FREQUENCY DRIVERS 1" (2.54cm) Aluminum diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
LOW FREQUENCY DRIVERS 6.5" (16.5cm), magnetically shielded IMG woofer
ENCLOSURE TYPE Bass-reflex via front-firing port
INPUTS Dual binding posts / bi-wire / bi-amp
HEIGHT 36" (91.44cm)
WIDTH 8" (20.3cm)
DEPTH 13.5" (34.3cm)
WEIGHT 40lbs (18.1kg)
FINISHES Black Ash vinyl
BUILT FROM 2010
P.s: Mods are welcome to move it to deals section
