Ok so I finally got the opportunity to install my DCX 2496 into my system, but had an issue....
For those that don't know, I had an SMS-1 and was outputting the same signal to all 4 subs (2 18" LMS's, 1 15" TC3000, and 1 15" TC2000) I'll be replacing the TC2000 as soon as my 3rd LMS shows up...
All subs are scattered around the room at different distances, which is why I moved over to the DCX so I could set distances for each properly, and thus far it has done a fantastic job and things are sounding better and tighter in that regard. Now after measuring with REW, we came up with a pretty nice response, but need to EQ 3 points. Which we entered into the DCX, but upon further sweeps, it showed no effect like the EQ wasn't working at all.
Also I thought the DCX was more capable, but it seems that there are only 3 EQ settings for each input, and 2 for each output. I could use more help clarifying how to set up.
My setup is 1 XLR from the Sub out on my Anthem D2v, to input (A) on DCX linking outputs (1,2,3,4) to each of my Amps.
I am trying to EQ globally in the single A input to cover the response, but its showing no difference in response after measuring.
