DCM Timeframe TF400 WOOPS!!
RickH
I am in the process of restoring a pair of DCM timeframe TF400's. When I removed the crossover I was careful to note the color coding of the wires. In my haste I did not notice a small coil that was mounted seperatly from the main crossover. I need to know how this wires into the crossover..Here is the wire coding on the crossover: Upper woofer,(has tweeter mounted directly above it) Red & Black
Lower woofer,Purple and gray, Upper tweeter,(mounted above upper woofer ):eek::green/black and yellow black, rear tweeter: brown and blue. also there is a 12 volt 1.4 amp lamp fuse on each crossover. can these be replaced with a standard 12 volt fuse? slo blo or fast?...I assume this fuse protects the tweeter. Thanks in advance for any help!
