OK, I should know this by now since its been nearly 2 years since my latest system. You use the +/- Db in set up to ajust the speakers to equal levels, right? Is there a optimum range, like staying as close to 0 or increasing to get a higher over all level. Also, when a receiver is rated for, say 100 w/per, is it at 0db or what. Just been prayin on my mind. Hope it makes sence to others. Thanks.
