DB Levels and Crossover freqs for this Setup - HELP!
HARIHITH
Hi all
After I bought those Def Techs , I could set them up last week!! Now my setup is
Speakers:
Definitive Technology
Model: BP7006BLA x 2
2. Definitive Technology - ProSub 1000 10" 300-Watt Powered Subwoofer
Model: PSUB1000BLA
3. Definitive Technology - Dual 5-1/4" 2-Way Center-Channel Speaker
Model: CLR2002BLA
4.Definitive Technology - ProMonitor 800 4-1/2" Bookshelf Speakers
Model: PROMON800 x 4
Receiver:
Onkyo TX 875
Any recomendations on the DB Levels and Crossover Freq. for this setup( 7.1).The Room dimensions are 17(L) X 11 ( W) X 10 ( H) .
I like to watch Movies and Games than to listen to music. I tried the Audessey Function in the Onkyo, and was not impressed and yeah, the Onyko only allows the receiver to be set up at either 4 Ohms or 6 Ohms no 8 Ohm Setting.
thanks
ParadigmDawg
ParadigmDawg
No one's settings will help you as the room is the key factor. Run the aut-cal, go back in and change the speakers to small and set the crossover in the 70-90hz range with the subs crossover disabled or turned high as it will go.
The other and best choice is to get a SPL meter and cal disc.
Speakers:
Model: PSUB1000BLA
Model: CLR2002BLA
Receiver:
Onkyo TX 875
thanks[/QUOTE]
AVRat
AVRat
Because they're Def Techs, I'd go a different route since you're running the DT ProSub.
X-over settings:
7006 - Full range
2002 - 60/80 Hz
800s - 100 Hz
Dbl Bass - On
Impedance - 6 ohm
I believe the ProSub x-over is bypassed when you use the LFE input.
A Radio Shack SPL (Sound pressure level) meter will help set the channel levels.
