G
gogunbaba
Hello,
I was planning to build a THT but gave up on the idea because of the size of it. I currently have an ED A5-350 that comes with a 550W amp and goes down to 17hz per its specs.
I would like to build 2 separate Dayton DVC 385-88 subwoofer using an ep4000 amp (I already have these equipment).
I am not sure if it would be possible but, the idea is to beat the performance of my current sub. My theater room is 19x14.5x8.
However, I have some limitations. The size of each box can not be larger than
22.5"W X 23.5H X 25D . I would like to build vented box if possible as It will go down to lower frequencies. These subs will be used for only HT purposes.
The idea behind this built is to beat the performance of my current sub.
can someone please help me with a design using the above dimensions?
Thank you for your help,
