Anyone ever used these ? Sent from my iPhone using Tapatalk
lovinthehd Audioholic Jedi Jan 9, 2019 #2 No, they sell out the UM-18 frequently because no one uses them They're quite popular but Dayton makes more than one 18", is it the UM-18 or which one do you mean? ps Even some pros use them, check out the Seaton F18.
B Brettc Audioholic Jan 10, 2019 #3 I already built this one about a year ago and was planning on putting it in the wall. Just got the wall ready . It’s a model RSS 4601..,,,,, recommends 1000 wt amp Sent from my iPhone using Tapatalk
everettT Audioholic Spartan Jan 10, 2019 #4 If your going IB, IIRC @TLS Guy had some thoughts on that driver.
Matthew J Poes Audioholic Chief Staff member Jan 10, 2019 #6 The RS is a good driver. Can’t speak to its use as an IB woofer, but as a driver it’s good. Very low distortion and good linear performance. Decent xmax for the price, but won’t compare with something like the ultimax or other higher excursion designs. Most of Dayton’s drivers are a great quality product for the price point they target. I use a prototype 18 made by one of their suppliers and it’s great.
B Brettc Audioholic Jan 10, 2019 #7 I’m going to have this mounted about 4’ height in a wall adjoining another room. Left rear wall . What’s your thoughts on using different for other in front or 2 or 3 ? Sent from my iPhone using Tapatalk
