Hi, I'm new here so I'm hoping that I asked this in the right forum. I have a hundred or so DAT tapes that I'd like to transfer to PC. I'm doing the same with cassettes and reels so I figured that DAT would be easier since they're already digital. Wrong. I can't find any USB import device that will take a coax or optical input, and although I do see a few soundcards that have coax or optical inputs, I'm not sure if they'll do what I want.
I have a portable Sony D7 that is sort of working and I have the 7 pin output > Coax cable for it, but my Tascam MK20 deck is dead, making things more difficult.
I have an old (vintage 1999) DATPort, which I once bought for just this purpose. It takes a coaxial input and connects to a USB port on the PC. But the drivers are for Win98 and the manufacturer (OpCode) is long out of business. But I plugged it in, Win7 found some drivers, and I tried importing some stuff from the D7. I'm using Audacity and I'm not sure I have it set up correctly for this but the DATPort does show up as an input device. It appears that tapes recorded at 44.1 work perfectly. Tapes recorded at 32 are too fast and garbled. Tapes recorded at 48 (the vast majority) cause Audacity to simply sit there with the recording line pinned to the left side of the window, shaking. Headphones connected to the D7 work perfectly.
Since the D7 is having trouble loading the tapes, I just got a used Panasonic SV3800 off Ebay. It works exactly the same in terms of how the three sampling rates work from the D7, except it won't even play the 32 tapes. They show in the display as 32, but after a few seconds of garbled noise the 3800 just freezes and needs to be turned off and back on.
So, any comments on how to do this without going through an analog stage would be greatly appreciated.
