(250$ for just the drivers) (an extra 150$ for the cabinet)(an extra 100$ for the xover)
if you want to buy send me you email so i can give my phone number an directions to my home
the items for sale are
my unfinished diy dual 10in center speaker for ht room all the parts needed are part of sale minus paint
for 400$ for the lot (250$ for just the drivers)(150$ for just the cab)(100$ for just the xover)
iv been unable to finish as funds are tight an while all the parts an pieces are ready
for final build to make other builds a bills i decided to sell all for half the original sale price -shipping an tax
1 x Three-Way EDC Crossover for Center Channel Speaker
made by Bill Daniels at dstechlabs.com to these specs (iv had some made for bookshelfs ther very good)
3rd order butterworth 3way at 1200/4000hz
with this config
600watts input at 8 ohms with
400watts at 4 ohms to the lows (should be wired in parallel for crossover connection)
100watts at 4 ohms to the mids (should be wired in parallel for crossover connection)
100watts at 8 ohms to the highs
2 flush cut router guilds for baffle cut an speaker mounting
drivers are
1 x Visaton HTH 8.7 Professional Constant Directivity Horn 8 Ohm
2 x PRV Audio WG275Ph 1" Horn Loaded Midrange 8 Ohm
PRV Audio WG275Ph 1" Horn Loaded Midrange 8 OhmThe compact and convenient WG275Ph from PRV Audio combines a wide dispersion bi-radial horn with a powerful midrange compression driver. This combo has been specifically designed to reproduce the all-important vocal range with authority. With 60° H...
www.parts-express.com
2 x FAITAL PRO 10PR320 - 10" SPEAKER 8ohm
Faital Pro 10PR320 lightweight neodymium 10 inch woofer for speaker replacement or upgrade. Faital Pro 10PR320 10 inch speaker for all high efficiency speaker systems. The Faital Pro 10PR320 delivers warm defined bass with 600 watts program power handling. Faital Pro 10PR320 speakers here.
usspeaker.com
twin slot ported 52hz cab exturnal dims 48.5in l by 13.5in w by 12.75in d
net inturnal vol 2.3cft
1 - 1.5in think walls with 1.5in front made of unfinished mdf (requires primer base coat )
back yet to be glued on (cab pro built by bill at dstech)
