Crown CT-400 -- can I use as sub amp?
E
E-A-G-L-E-S
I was wondering if I could/should use a Crown CT-400 as a sub amp?
It would require a special cable Isuppose, can it handle the load?
Or is it not appropriate for this use?
jamie2112
The Crown will power a sub just fine. It will give you 440 watts bridged in mono, which is what you want for your sub......
E
E-A-G-L-E-S
Great!
Where can I find a sub cable with a padl on the amp end and a plug on the sub end?
Thanks!
jamie2112
No worries, thats what we are all here for. Glad I could help...
E
E-A-G-L-E-S
O.k., got ahead of myself.
I'm not exactlky sure what I'm looking for.
Is it an audio cable or a power cable?
It is sub audio cable connecting the amp to a power connection terminal I must install during my cabinet build correct?
Thanks for helping a confused guy out.
