big2bird
Gents,
If you wanted to try a new Crown amp in your home system, and you could buy any one of them, which would you try?
jinjuku
jinjuku
Moderator
Depends your scenario. For straight up, affordable amplification, it's the XLS Drive Core. For affordable, DSP controlled, higher wattage it would be the XTi2.
For no holds barred Class A type, but more efficient, higher than Class A wattage it would be their I-Tech HD.
The I-Tech will need to be housed outside the listening area since they have loud fans.
For distributed audio it would be the CE series (70 volt).
What problem are you looking to solve?
BoredSysAdmin
BoredSysAdmin
* If going with XLS Drive Core series - start from 1500 model or up if needed. Some of 1000's specs (besides power) are just a bit not as good
