Hi, I'm am new to this and I've searched the web looking for crossover frequency information. I understand what crossover does, but what isn't clear is if it's for just the front L/R speakers or if it's for front L/R/center or for all my speakers (front L/R/, center, surround L/R/rear). By the way, I have the ONKYO TX-SR502B receiver.
Another thing is, I have some old JBL that I use for my surround and center. The specs are identical to the satellites and center which is a freq response of 120hz-20khz. I am using Polk Audio R30 for my front L/R and I believe the the frequency response goes way lower (55hz-20khz). My question is depedent on the answer to the first question. If the crossover is only for the front L/R, then I'll set my crossover freq to 80hz, but if it's for all my speakers, what should I set the crossover to since I'm limited to 120hz-20khz for my center and surrounds and my front L/R goes down to 55hz?
Also, will setting my front speakers to "Large" cancel the crossover frequency that I set? I read somewhere that if you set the front to large, then the receiver sends the full frequency to those speakers, and if you set it to "small," then the receiver will send only the higher frequency depending on the crossover.
Last question. I have a feature called Double Bass or something like that. To my understanding, if you turn it "ON", it takes the bass from the front speakers and sends it to the subwoofer. Does this mean that it cuts those frequencies out from the front and sends it to the subwoofer or does it send those freq to both front and subwoofer?
Sorry for asking so many questions. Thanks in advance.
