Buckle-meister said:
I wouldn't have thought so. The higher the crossover setting:
1. The less strain you are putting on the amp to drive the other speakers (good)
2. The less strain you are putting on the speakers to deliver frequencies that the sub is almost certainly better at reproducing (good)
The only downside I see to a crossover setting of 100Hz is that you may be able to perciece the location of the sub for frequencies from approximately 60Hz to 80Hz up (bad)
Regards
While it might sound like a good idea to cross a sub at 100Hz(aside from the localization issue that you are already mentioned), in reality, it probably is not a good idea, unless the subwoofer cabinet was specifically designed to do so.
The residual higher frequencies that are output above the crossover frequency will be affected under the proper conditions. For example, take a 24" cube; this dimension will have an inherant strong cancellation/notch at 140 Hz, and an inherant substantial resonance at 281 Hz(this happens to reside in the most sensitive band for human hearing detection of resonances). If crossing this speaker over at 100Hz using a 2nd order crossover, a significant resonance will occur, centered at 281 Hz that is only a few dB under the reference signal amplitude(because the resonance will be amplified substantially in the cubed chamber). A cancellation/notch at 140Hz will also have an effect on response, in that amplitude will not decrease linearly as frequency rises. The subwoofer needs to have been specifically designed to handle such a crossover point/slope, by way of dividing chambers or by way of dense/thick acoustical damping materials. For a frequency as high as is proposed, to be effective, the internal dampening material should be 2" rigid fiberglass lined walls, or 4" acoustic foam lined walls, or a 100 percent heavily stuffed(with regular fiberglass) volume. Even with a 4th order slope, these precautions should probably be heeded if using this high of a crossover frequency if the physical conditions are as cited in my example.
This is, of course, a dynamic situation, and the specific circumstances(which are not yet known in sufficient detail) dictate what needs to be done for optimal behaviour.
-Chris
