Folks don't get my suggestion wrong here. I never said that EQing the output from a preamp would defy the limitations of his speakers, and magically convert the Woofers into Subs. (Physics is physics you know...) It will allow him diminish the output of those sounds above the output of the Woofer's normal limits; so he won't be saying "the mids and highs are deafening" and then he can hear what the Woofer is capable of producing. Boosting the Bass may not result in what he is looking for, but he should be able to see if the output approaches the lower limit of the 380SE woofer's specification (20Hz). (It is crossed over @ 250 Hz.) Tweaking these settings is all reversible.
Luke, thanks for the info "I have my computer connected to the TV via HDMI and then audio out from the TV to the power amp." I'm a little concerned for the quality of the sound headed into the Amp. You can't make decent sound without good material, and a clean pathway for it (Garbage in /garbage out).
A couple more questions. Please advise what drives the HDMI output in your PC. Please advise what soundcard is in your PC. And just how do you hook up your TV to the Amp. And lastly, do you have an optical drive in your PC with a CD or two you can use as source material? (I'm assuming you use a lossy file format like MP3s on your PC. Please advise details.) FLAC files are slightly compressed audio files that, unlike MP3s, are not missing any of the original information of the source material. When you play a FLAC File it's like playing the CD (if the FLAC File was created from a CD) and sounds identical to it. ( From xiph.org => FLAC stands for Free Lossless Audio Codec, an audio format similar to MP3, but lossless, meaning that audio is compressed in FLAC without any loss in quality.) My intent would be to go direct from your PC to the Amp to eliminate the TV (for now) in the equation. Let's try to get some clean source material and go from there.
