Crossover impedance
bobolink
<font color='#000000'>I have a 3 way crossover that I would like to connect a 8ohm woofer and tweeter to and a 4ohm mid I have a 4 ohm resistor how should I place the resistor in the mid range circuit to compensate for the mids 4ohm resistance? Is this possible?</font>
av_phile
<font color='#000000'>Connect the 4 ohm resistor in series with the 4-ohm midrange to get 8 ohms. &nbsp;That resistor should have sufficient power handling ability. &nbsp;Since it gets half the voltage going to the mids, it will heat up during operation.</font>
