Hi All,
I have a little dilema. I got the sub from klipsch (RW12D) togheter with the Klipsvh Quintet 5.
Great system and sound really nice! But something is disturbing me and i need some advice.
The klipsch RW12D have a freq response of 24-120Hz +/-3dB. While the quintet have 110Hz-23kHz.
The best would be that i set my reciever at 120hz crossover, i guess. But unfortunately my reciever does not deliver that setting of 120hz.
It goes from50hz,80hz,100hz to 150hz and 200hz. So the question is, what should I do with that. If i set it at 100hz, it can be that my sattelites will bring distortion? Or will that difference (10hz) be to small to hear? The other solution is that i set the crossover at 150hz. But my subwoofer handles max 120hz. Means that everything between 120hz and 150hz will be lost because the sub can not handle it?
Many thanks in advance
regards
Klaus
