FS: CRESTRON TOUCH PANEL BEST OFFER TAKES IT! NEVER EVER PROGRAMMED!
This touch panel retails for over $2000.00 brand new. I just want to get a decent amount of money for it. It's been sitting dormant for over a year and a half, and I've never had it programmed. You may have to replace the small battery pack which sells for no more than $100.00 on eBay, and other dealers of Crestron Gear. I don't have the paper work for it anymore.(sorry)The reason you may have to replace the battery pack is because it's been sitting for so long. Panel Info: Crestron ST-1700C, 1-Way wireless Touchpanel. This unit comes with all items shown - Touchpanel, Powerpack, Charger with power supply.
The Touchpanel ST-1700C is marked with a PM3, a T33, and is Part # of 6002123.
The Powerpack ST-BTPN has a Part # of 6001590 on the back if the battery.
The Charger ST-DSN has a Part # of 6001592.
The Charger power supply has a Part # of PW-1215.
The Receiver that is needed to use this particular touch panel(also, this receiver can be used with most Crestron panels)CNRFGWA is marked with a V5, and a Part # 6001130.
The ST-1700C is a stylish and compact 1-way wireless touchpanel featuring a brilliant 5.7" active matrix touchscreen and optional pushbuttons. Isys color graphics and long-range RF communications combine to deliver amazing touchpanel performance with complete freedom of movement.
For more information please check out Crestron on line at -
http://www.crestron.com
you can also contact me at my email address:
Gatsby191@aol.com
