Cresta 10 or Epos ELS3???
jingka
Hi guys,
If you are to choose between Cresta 10 and Epos ELS3, which one will you choose and why?
Basically, I have only these two to choose from as a starter setup...I like to collect info regarding these two bookshelf speakers and your valuable inputs will be very much appreciated.
Thanks...
jcPanny
jcPanny
Bookshelf speakers
I am not familiar with eaither of those models, but if you post your speaker budget, you will get plenty of suggestions.
My advice is to identify several models in your price range. Research and reviews are great, but the best option is to listen and let your ears decide.
Is your amp 4 Ohm stable? The ELS-3 is 4 Ohm and low sensitivity, but between the two it would be my choice.
