thanks for the reply.
Yeah I think it would be more for home theater (hope thats what you meant by "HT"
The Microlab you posted looks decent although I havent seen any reviews on it yet. I suppose its more or less the same as the FC360 that I listed.
So you think I should rule out the 2.0s? Are those mostly for music?
So I'm a bit of a newb in terms of audio systems.
