CRC QD electronic cleaner
O
ohsolo
Can CRC QD electronic cleaner be used for cleaning pots and switches. CRC said it is a quick drying solvent to clean and protect sensitive electronic payment. I am thinking of using it to clean my Kenwood LA 9100 amp. I would appreciate any help on this question.
slipperybidness
slipperybidness
Looks to me like it is designed for that type of application.
Read some reviews on Amazon.
https://www.amazon.com/CRC-05103-Electronic-Cleaner-11/dp/B000BXOGNI/ref=asc_df_B000BXOGNI/?tag=hyprod-20&linkCode=df0&hvadid=198054130793&hvpos=1o1&hvnetw=g&hvrand=13267987177379235690&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028287&hvtargid=pla-379166032540&psc=1#customerReviews
Personally, I use the DeOxit brand. But if you already have the CRC it should work fine.
