Hi,
I read across forums about the issues with Crank 2 BD and I wanted to share my experience and gather inputs.
I have a Panasonic BD60K bd player. When I tried viewing the Crank 2 bd movie as usual I faced the square image issue on the screen and sound began to play without video etc.
Now i tried using a microSd card(since i had this card first) encolsed within a SD card adapter and inserted it in the SD card slot of the player. The player tried to download the upgrade but for some reason it could not complete the upgrade.
I borrowed a separate SDHC card(class4) and repeated the same process and it worked - though I had to connect to the internet in both cases.
I checked the SDHC card and observed that the upgrade file is less than 100 MB. So I tried copying the upgrade file from the SDHC card to the micro SD card to see if it works with the microSD card(with the SD card adapter). But unfortunately it didnt.
I would like to understand why didnt the upgrade work with the microSd with SD adapter card, so I can avoid purchasing a separate SD card
just for a 10$ bd.
And now if I want to view the BD again, do I need to connect to the internet everytime?
Can someone please help me with this issue?
Thanks.
