Crackling when changing the volume
abefroeman
abefroeman
I bought a 1985ish NAD 7155 stereo receiver off of ebay and it sounds great. But when twisting the volume knob there is a crackling sound that is about half as loud as the music that is playing. It starts when the knob starts to twist and stops when you stop twisting.
What is this and how can I fix it?
I suppose I could call NAD. I will try that in the morning.
zildjian
zildjian
First, try (with the unit off of course), turn the volume knob back and forth from all the way max to min, do this many many times. This itself may help self clean the contacts. If that doesn't work, you may call NAD and ask them if it's ok to use contact cleaner on it. If you can pull the volume knob off and access it's contact with one of those tiny plastic straws that comes with the spray can, just a tad of the cleaner should help, too much can get elsewhere and cause problems.
moverton
The volume pot has carbon dust in it. This is very common on old pots. It is very easy to fix. Instead of writing it up myself, here is a link.
http://www.axiomaudio.com/tips_cleaning_staticy_controls.html
Coincidently, I myself bought a 1980's NAD 2600 with exactly the same problem. That was why the guy sold it so cheap. 50 cents of pot cleaner fixed it. It is an awesome amp. Those old 80's NAD class H amps are the best bang for buck i know of. Mine is something like 150 watts with 6db headroom and can kick about 40 amps current. NAD later got away from the high headroom amps and went downhill imo. I don't think they could ever get people to understand high current/high headroom amps. Everyone just looks for watts.
misty
Just wanted to express my thanks for the information in this thread. I just purchased a great looking GE 7-2945A radio through ebay. It is so well cared for it looks almost new. I'm going to guess 1975- 1985. When I turned it on, the volume knob caused very loud crackling and hissing, to the point I feared it would damage the nice speaker. I took the advice in this thread, and it was immediately repaired! Now I have an excellent little radio with tone control, and a speaker that out performs my new portable radios. Thanks!
Ampdog
Abe,
Should all fail (the track itself may be worn) and a replacement is not readily available, there is one last way out. One can mechanically move the slider to an adjacent unused portion of the track, which is usually quite wider than required. This will however require precision and an ability to do tiny jobs, preferably using a magnifying glass and sufficient light. You will have to remove the pot(s) and disassemble, making notes in order to reverse the procedure. Normally the slider has two 'prongs' sliding on the track, having worn a circular 'path' with time. With a tweezer or similar (best having removed the spindle proper) one might be able to position the sliders to move on a virgin part of the track between or either side of the worn paths. One needs to keep the contact part of the prongs as well as the track pressure similar than before.
Repeating, it needs a steady hand and preferably experience, but can save a control when there is no other way out. I have fortunately been able to perform this several times and with (so far!) no complaints. Again, before replacing, turn the spindle back and forth several dozen times.
Good luck!
LAB3
LAB3
ImcLoud
ImcLoud
I am sure abe has this fixed by now, considering he bought the amp over 7 years ago, lol...
Misty welcome to the forum...
LAB3
LAB3
My link was anyone else with this problem. As I did notice the date :rolleyes: and noticed Misty had the same problem.
ImcLoud
ImcLoud
And my post was directed to ampdog, seeing how I was probably typing while you were posting yours check the time stamp again... :rolleyes:
LAB3
LAB3
It does not matter who you were making fun of. :rolleyes:Your post was of no help to this thread.
ImcLoud
ImcLoud
you need to get over it, :rolleyes: My post was so that 20 other people didn't chime in with advice to someone who probably doesn't even own the equipment anymore, the post you were supposedly responding to was simply someone saying thank you, that already fixed their problem... Anyway, not trying to start an argument, not "making fun" of anyone since I am not 11, just a courtesy so that no one else replied to a 7 year old post, its a common practice...
LAB3
LAB3
I am not upset.......nothing to get over on my part. It was your attitude...... as it came off like you were making fun of US that posted links on how fix this problem. And this info from the links we posted will help 20 other people that read it. Have a nice day.:)
ImcLoud
ImcLoud
my comment wasn't even direct towards you, and I already explained myself, it is common to let someone know when they are posting in a 10 year old thread... If you have issue's where you think you are being made fun of and don't like my "attitude" then block me, no big deal, I will do the same and will have a nice day, thanks
http://www.youtube.com/watch?v=r5TKtu30vEU
LAB3
LAB3
Cartman (da F#ck) - YouTube
ROFL ;) you need to let this go.
