It's definitively from your electrical wiring or some type of radio interference, generated at constant intervals, and travelling through your electrical system.
It might need a ground isolator plus noise insulator, or a wire replacement.
Try this: Turn your main breaker Off, and turn all your other breakers Off.
Then turn them back ON, after about a minute or so.
If the problem persist, call an electrician and get an estimate of the problem and cost.
Bob
