Redbone said:
I put a two prong cheater plung on my NAD three prong plug. It seems to have fixed the problem I hope it is a viable and correct solution. All components in my system with the exception of the NAD have two prong plugs.
Why do you need a three prong plug and how does it effect a system?
The third prong on the plug is a safety ground. It is tied to the case of your receiver and is only there to provide a guaranteed path to ground in the event that there is a fault in the product that energizes the case or any other user-accessable area.
Your receiver (probably) has transistors mounted on heat sinks. The case of the transistor is usually at the negative rail voltage (-50V or so). If the insulator between the transistor and the heatsink were to fail and there were no third wire in place, then the heatsinks would be at a -50V potential, and since the heatsinks are usually screwed to the chassis at some point, then the chassis would also be at -50V. Potentially hazardous for the user.
With the third wire in place, the chassis is guaranteed a low-impedance path to ground. If the insulator fails and the third wire is in place, then the amplifier's -50V supply is connected to ground, which blows the AC fuse on the receiver, protecting the user.
The third wire is a requirement for UL listing and is just safe practice anyway. Your other components do not have a third wire because they are low power devices and do not constitute a safety hazard, are double insulated, or conform to certain internal component spacing rules (or some combination of these three).
